Re: Sediment bowl seat
Posted by Bob M on November 17, 2009 at 11:47:04 from (151.190.254.108):
In Reply to: Re: Sedament bowl seat posted by S/C BOB on November 17, 2009 at 11:40:36:
Ummmm....I don't believe there is a separate seat in the sediment bowl assembly. Rather the "seat" is simply machined directly into the zinc casting.
I suspect your sandblasting tore up the seat area in yours. Or perhaps there's a bit of sand now embedded in it.
Either way your best bet is to purchase a whole new sediment bulb assembly. They're readily available and not terribly expensive.
