IH Farmall 504
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Nancy P. on April 25, 2000 at 06:35:20 from (207.179.163.35):
Morning... lots of info here but I need help. MY hubby and I are doing a motor job on our tractor. It had a piston slapping noise and decided to check it out. Good thing too, one piston was broke and laying in the oil pan. Tractor works good and need some help getting parts. The crank has already been turned down once and can't do it again because won't be able to find bearings to fit it then. Does anyone have any suggestions on a reputable dealer for second hand crankshafts to fit this model (gas engine)? We've gone too far to turn back now and need the part. We will buy a new one if we have to but not sure if that can be found either. Anyone with any help to offer... please reply ASAP. Tractor is tore apart and we need to get her up and running again.
Many Thanks,
Nancy P. (NB, Canada)
Post A Followup
: Re: IH Farmall 504
