Okay. It seems like you can follow wires alright. And from your descriptions, it sounds like you're set up for negative ground which suggests you're running 12v on an alternator???
If you don't see a solenoid anyplace in the works, check out the diagrams on the link below. BobM, who is around here a lot, has very kindly worked up some clear wiring diagrams and makes them available at the link. Check out #3 to begin with. It shows a saddle-mounted starter switch, but Bob notes that there might be a separate loop that the schematic doesn't show that would accommodate a remote starter switch.
If that isn't just it look around the others to see if one is a better fit.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
