Posted by Wardner on November 18, 2009 at 06:04:29 from (4.154.240.181):
In Reply to: Re: 400 LP regulators posted by redgems on November 17, 2009 at 20:45:02:
Redgems,
Your info is discouraging but you confirmed that most older regulators will have problems.
My local IH dealer can get the spring thru an obsolete parts house. The partition plate only restrains the movement of the low pressure diaphram and is not subject to a pressure differential from either side. It can probably be cleaned up and epoxy coated. It might be a good preventive measure to remove the idle adjustment screw and squirt something like WD-40 periodically. The silicone spray should help.
I will get the Ensign regulator to function. No plans to upgrade to anything else.
Today's Featured Article - A Tinker’s Guide to Manifold Repairs - by Curtis Von Fange. A common characteristic of keeping older equipment is that some parts to make repairs can be extremely difficult to locate. For example, finding a replacement for a cracked intake or exhaust manifold on a unique tractor or odd brand can be a frustrating and downright impossible mission. So, what is an alternative solution to scraping out that ‘one of a kind’ piece of history? First, decide if you are one to try a repair yourself or have someone else do it. If you are uncomfortable about
... [Read Article]
Latest Ad:
[More Ads]
