Re: WD 9.... 6 or 12 volt
Posted by Janicholson on November 18, 2009 at 06:15:19 from (199.17.6.222):
In Reply to: WD 9.... 6 or 12 volt posted by plow hand on November 17, 2009 at 17:09:00:
I believe they were positive ground. It will likely work either way. I would hook up the battery with the polarity determined by the size that the terminal clamps are being used now. Big post in big clamp etc. Then, without starting it, I would turn on the lights. If the Amp meter moves to discharge I would go with it as is. If the meter moved to charge (the wrong way) I would reverse the polarity of the batteries, and run it that way. Again do not start the tractor for this test! JimN
