Voltage is your problem. The more voltage your coil is putting out, the more interference you will cause. Shielded wires and resistor plugs will help, if that still doesn't do the trick you may want to see if you can shield the coil.
If all else fails, and you need to run a generator with your tractor, look into a Faraday cage. Basically a grounded copper mesh enclosure, this will contain all of the EM interference.
PS if you ever want to disrupt all computers, radio, tv, etc, build a reasonable size Tesla coil. I had some friends that inadvertantly over powered a nearby radio antenna with theirs. They got a nice warning from the FCC once they figured out what was causing the problem.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
