Re: 12 volt battery hook-up
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by MrG on April 25, 2000 at 09:26:38 from (216.170.12.242):
In Reply to: 12 volt battery hook-up posted by TIM LUCAS on April 25, 2000 at 08:44:22:
I don't think it matters Tim, the starter is only going to spin one way regardless, and the coil should stay connected between the switch and the ditributor just like it was. You will need a resistor in line to use a 6 volt coil with a 12 volt battery (NAPA # 13ICR I believe).
The coil windings are "ground" dependent not "polarity" dependent and will actually deliver poor performance if the not hooked up correctly...I got quite a eyeopener when I asked this quetion myself on the Farmall board!
Post A Followup
: Re: Re: 12 volt battery hook-up
