Posted by pete 23 on November 19, 2009 at 16:39:24 from (173.87.147.73):
In Reply to: 400 d posted by tonastoy on November 19, 2009 at 11:46:39:
IH changed their minds many times on that 12 volt with or with out ballast on the diesel models. Latest was, 6 volt coil, no ballast as they felt you ran it such a short period of time the hotter spark outweighed the high current flow through the points. And yes, the manifold switch must be operating to shut off ign when on diesel cycle. Lot of them switchs failed so they were bypassed by hooking both wires to same terminal at the manifold switch. Then of course you had to be sure to shut off ign switch or points and coil would burn up. I would venture to say we replaced more coils on the diesel models than all the gas models combined in their hay day.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
