Posted by ScottyHOMEy on November 19, 2009 at 17:41:26 from (71.241.218.96):
In Reply to: Brake Locking on Super M posted by Buckskintractor on November 19, 2009 at 17:10:52:
Hate to be the one to say it, but if the brakes were badly worn overall, that's what will happen if you only do one side. If you can't slack off the good brake and tighten the worn one to get them in balance, it only folllows that one side of the tractor will stop faster and harder than the other.
That and having the splined shaft clean, with nothing more than a touch (maybe! at most!) of graphite is to be preferred to an oily or greasy lube, which will only accumulate dirt and cause the discs and plates in the middle to bind on the shaft. Next time you open them up, clean that shaft and the internal splines on the moving parts with a brake cleaner. They're normal operation will be better dry than gummed up.
Other than that, it may also be, if you had the cover planed down, that they took too much off and there isn't room for the discs to float.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
