Re: 12 volt battery hook-up
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by The Red on April 25, 2000 at 09:26:49 from (206.246.187.2):
In Reply to: 12 volt battery hook-up posted by TIM LUCAS on April 25, 2000 at 08:44:22:
Nope not really. If you are negative ground, make sure that the wire from the coil switch is hooked to the positive post on the coil. The negative post wire goes to the distributor. Also make sure you have a ballast in that coil line if the coil is 6 volt.
Post A Followup
: Re: Re: 12 volt battery hook-up
