Start on gas and run long enough to warm it up adequately to switch over to diesel. This will be almost instant if it's already warm, otherwise 2-3 min (whenever you're running on gas the starting valves receive little to no cooling and the longer you run the hotter they get). Then on diesel gently warm it into work.
For shut down, idle on diesel for 15 min or so after hard work until it's as cool as it can get still running. Then switch it back to gas and after a minute or so shut it down (I normally just turn the gas off and let it run out). Once the engine stops turning switch it back to diesel to let the starting valves cool on the head.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
