dave's right carter and gruenenwald has the kit about 150 dollars or so, comes with upper and lower bushings, bottom bearing, upper seal, also bearing and seal for the worm gear shaft, and i thing also the bushing for the worm gear shaft. not too bad to change them, they can either be pressed in or if you have a long piece of all thread rod, you can make a puck to pull the lower in. if you miss the hole for the grease zerk, just remove the zerk from the bolster and drill a new hole.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
