ACN said: (quoted from post at 19:33:06 11/19/09) Hello looking for info/help.... recently purchased a 62 340 with an international 2000 loader. Loader moves very slow and has little power. looking for any advice or fix to this thanks in advance
I have the same setup (340 with 2000 loader) and mine is using the tractor hydraulics with the transmission mounted pump. Changing the filter and fluid really brought mine around. If yours is using the tractor's valves, make sure the selectors are set to single acting for the lift cylinders and double acting for the bucket. The little clip that keeps the selector in place is missing on my bucket valve and it moves to a position in between single and dual, causing the bucket to move slowly. Mine also has an elbow and 3" pipe nipple screwed into the level plug (by the LH foot board) to raise the hydraulic oil level to keep from starving the system. If that doesn't do it, I'd look at the pump and valves.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
