Re: Interesting LP conversion on '41 M
Posted by Wardner on November 20, 2009 at 19:17:58 from (4.154.246.9):
In Reply to: Re: Interesting LP conversion on '41 M posted by NDS on November 20, 2009 at 18:04:31:
NDS,
Now you are creeping me out. Are LP tractors inherently more dangerous than gasoline tractors? After all, a gas tank can be easily pierced. Or ruptured like a Ford Pinto.
It should be pointed out that IH used unshielded copper tube for the liquid and vapor lines to the filter and on to the regulator. And curiously, on the same machine, IH used steel lines for moving water to and from the evaporator. That doesn't seem to make much sense but there must have been a good reason.
The IH engineers also placed the valves facing the operator's position. This arrangement seems better than front, left, or right side of the tank. Less chance for a tree limb or other stationary object to do damage.
Can you describe the LP tractor accidents that you are aware of.
