Re: m belly pump
Posted by Andrew Z on November 21, 2009 at 07:37:33 from (137.36.216.94):
In Reply to: m belly pump posted by leak on November 21, 2009 at 06:17:05:
its easy. you just need to jam the pump gears with a brass rod and thread off the drive end. then remove the cover replace seal and gasket. hardest part of the job is getting it back up there. 3 guys works out best two hold the pump up with a rod 3 person makes sure the coupler stays in place and thread the bolts.
Andrew
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
