Re: Brake Locking on Super M
Posted by scot in pa on November 21, 2009 at 14:58:47 from (12.171.163.24):
In Reply to: Brake Locking on Super M posted by Buckskintractor on November 19, 2009 at 17:10:52:
I need to pull mine apart and put some more HIGH-TEMP anti-seize on the rollers. The copper-based stuff won't gum up like the graphite-based. When I was using it regularly, I cleaned them up and re-anti-seized them once a year.
I have to get those bearing cages in, I think that will help with mine locking up.
I always kept a large wrench on the PTO lever. Reach down and smack the face of the drum hard. That will usually release them.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
