Posted by robgIN on November 21, 2009 at 15:17:57 from (70.224.32.30):
In Reply to: 10-20 oil pressure posted by Tony S. on November 20, 2009 at 21:22:53:
Oil pump on the old ball bearing engines just circulated oil through the filter and then squirted some into governor housing and then had nozzles that filled splash trays for the rods to scoop up oil to lube rod bearings. Engine was splash lubed, you had to manually oil valves up top by putting oil into the trays and felt wicks kept the valves oiled. Pressure was likely 10 to 15 lbs as they said.Sounds crude, but look how many are still running 75 yrs later.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
