Re: To kit, or not to kit?
Posted by HENRY E NC on November 22, 2009 at 04:37:33 from (67.142.163.38):
In Reply to: To kit, or not to kit? posted by Mike CA on November 21, 2009 at 19:04:56:
I would be very careful about doing an engine kit now. If its not smoking just go on . Foget the kit. As said below it will cost much more than $600 when you open it up. I found out the hard way. As far as tires, I put new rear tires on my M for less than $600 . Look at several different sizes because I found out that the more popular tires sell for lots more than what I got.(Which were 15.8's)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
