Re: Super C Starter Drive
Posted by gene bender on November 22, 2009 at 09:22:44 from (67.55.226.179):
In Reply to: Super C Starter Drive posted by Smith1000 on November 22, 2009 at 06:30:21:
Before you do anything with the starter you better turn the engine over slow and inspect the teeth on the flywheel. Using 12v with bad drive and ring gear messes everything up. Bet a big steak the ring gear is also toast. It wont help to replace drive as the bad spot will just get worse then another drive will be needed. You can just take the ring gear off and reverse and install if the teeth arent too far goneas lots have been don3 that way.
