Wow! I don't recall a post that ever started out with that much information. 'Grats and thanks for being so thorough.
Your problem is most likely going to be too much air or not enough gas. On the first, you do need to check for an air/vacuum leak somewhere around the manifold. It could be as simple as loose or deteriorated gaskets, either at the head or at the bottom connection to the neck of the carb. Worse cases might be a crack or hole in the manifold, or a blown head gasket (a compresssion check might be in order to eliminate the latter). The easiest test is to get it running, and then spray a little aerosol carb cleaner into the area. If the motor stumbles or bogs down further, that would indicate a leak, and a more careful control of the spray from that point will help you locate it more specifically.
It does sound as if you've worked over the fuel supply side. You could try eliminating or replacing that inline filter (be sure any new filter is compatible with a gravity feed system -- many are designed to require the pressure of a pump and make for problems on the gravity feed tractors).
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
