Re: Hydraulics fo Log Splitter
Posted by glennster on November 22, 2009 at 16:39:37 from (24.14.63.246):
In Reply to: Hydraulics fo Log Splitter posted by Doug Kieta on November 21, 2009 at 17:24:53:
i would be leary using the hydraulics on a super a to drive a splitter. it has a small pump and that would prolly put a lot of strain on the cam and distributor drive gears. the belly pump hydraulics on an h would prolly be better, but its a lower pressure pump, and you will need a big diameter cylinder, about 5 inch, to get good splitting power. i ran my splitter of the belly pump on my m, it worked, but not real fast cycle times. what i do now is run a pto driven hydraulic pump (prince) on my farmall b. works real good.
