Re: H countershaft bearing retainer removal?
Posted by Janicholson on November 22, 2009 at 16:54:26 from (64.61.212.63):
In Reply to: H countershaft bearing retainer removal? posted by Jane Enright on November 22, 2009 at 16:46:10:
The countershaft is the lowest shaft in the access hole (driving the Liftall pump if equipped).
The drive coupling needs to be taken off of the shaft to access the seal. Lefty loosy with a 1/2" square steel bar or piece of 1/2" keyway welded to a socket. Tractor in high gear and blocked to allow high torque to be applied, they are real tight.
If it is the upper one (above that, it is the input shaft, and has a drive coupling to the clutch shaft on it. ??? which is it. JimN
