After checking what previous posters suggest I will just add, don't over look rest of ignition system. They can do weird thing to you some times. Last week I went out on a job, Farmall 400 gas tractor. It started acting up for my guy and he said he was able to keep it running by pulling choke but eventually it would not run any more. Turns out points were not opening at all by then so no ignition. I just opened up the points a bit to get it so he could use it to auger some corn and told him I would need to rebuild the distributor as shaft was very loose. Also found out CASEIH now offers a bushing rebuild kit so will find out how that works out as we could never get bushings for them all the years I worked at a dealership.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
