Posted by Janicholson on November 22, 2009 at 17:27:59 from (64.61.212.63):
In Reply to: Super M hyd. posted by Roy Ward on November 22, 2009 at 17:13:00:
First is that the front elbow on the left, or the right elbow are either good to use. (not the rear left, it is a delay port for IH implements of yester year. The pump runs all the time the clutch is out any way. If the system you put together is open center, it will be fine. The return hose can cause the original fill cap to leak oil like a stuck hog. Either gasket it off to not breath (OK with a two way cylinder), or attach the return to the bottom of the liftall with a T fitting. JimN
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
