Re: Farmall 100, engine questions, possible coolant in oil
Posted by Andrew Z on November 22, 2009 at 17:31:44 from (64.252.130.179):
In Reply to: Farmall 100, engine questions, possible coolant in oil posted by 440roadrunner on November 22, 2009 at 17:23:19:
Coould be all the things you said. The block is a wet sleeved so its possible the "O" rings at the bottom of the sleeve are leaking. Best thing to do would pull the oil pan and look up sometimes you can see rust streaking where it is leaking from. If not then fill the rad. back up and look for driping.
Andrew
