Re: Farmall 100, engine questions, possible coolant in oil
Posted by ScottyHOMEy on November 22, 2009 at 17:35:08 from (71.241.215.136):
In Reply to: Farmall 100, engine questions, possible coolant in oil posted by 440roadrunner on November 22, 2009 at 17:23:19:
Condensation can build up more water in the crankcase than you might suspect.
If you've got anti-freeze in your coolant, the color would be the giveaway as to whether it's condensation or a cross-leak somewhere.
It is a wet-sleeve motor, so leakage around the O-rings at the bottoms of the sleeves is another possibility in addition to the head gasket or cracks in the block or head.
