Re: Farmall M Runs When Chocked - Need Help
Posted by El Toro on November 22, 2009 at 18:50:33 from (74.103.74.58):
In Reply to: Farmall M Runs When Chocked - Need Help posted by Sparetime on November 22, 2009 at 15:46:17:
third party image
That fuel filter may be the problem if its not for gravity flow fuel system. Open that main jet adjustment screw near the bottom of the carburetor. That's how you enrich the fuel mixture on these tractors. Even garden tractors have them similar to the one in this picture. Hal
