Re: 450 LP Revisited
Posted by D Slater on November 22, 2009 at 19:54:16 from (72.65.155.239):
In Reply to: Re: 450 LP Revisited posted by Blackland Dan on November 22, 2009 at 19:17:05:
In the space between valve cover and and edge of head on manifold side you should feel dips or pockets above and between intake and exhaust ports. most times with oil or crap in them on well used machines. All other heads are pretty flat between the head bolt studs on that side.
