Re: Farmall 100, engine questions, possible coolant in oil
Posted by gene bender on November 23, 2009 at 04:17:20 from (67.55.226.179):
In Reply to: Farmall 100, engine questions, possible coolant in oil posted by 440roadrunner on November 22, 2009 at 17:23:19:
After changing fluids if you still think you are getting oil into the coolant you need to remove pan and look with a good lite at each sleeve you will be able to see the cooland at the bottom of the sleeve if thats where it is coming from. This mite take a few days for the coolant to appear. Nest would be the head gasket. You should see coolant in the oil when you drain if you will let the tractor set for a few days before draining as it will collect in the drain plug and you will see when you remove the plug. Sometimes it is hard to find just where the leak is coming from. It sounds like you dont know just think you have a leak so dont get too upset just now as you will find the leak.
