Posted by Brad in TX on November 23, 2009 at 15:08:11 from (209.137.232.122):
In Reply to: sediment bowls posted by oldiron25 on November 21, 2009 at 17:59:59:
I had this same problem for a long time until my FIL told be how to set the gasket. First, use a new cork gasket and put it on and finger tighten the screw on the bail. Turn the valve on the filter on and fill up the filter, gas will likely start leaking from the top. With one hand, press the glass bowl up against the gasket and loosen the bail screw with the other. You should be able to get the leak to stop with a very slight twist of the glass bowl against the gasket. Once you've found that magic spot where it doesn't leak by twisting, hold it in place and finger tighten the screw on the bail. Been doing this for some time now and it seems to work like a charm and has stopped my leaking sediment bowls. Good luck!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
