Is your hydralic system staying on demand now, engine laboring. If so, eiether the draft control spool stuck in raise positon, or some internal linkage came unhooked or broke. If it is not on demand, then your sensing link from torsion bar has slipped past upper link and you can get at it from third arm plate in rear and repositon it. May need repair or modification to keep it from happening again. If spool stuck, I usually reach in from rear and push against spool with with long thin screwdriver to lower hitch and usually valve will release then but it may happen again which would require removing and polishing it up or clearing contamination.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
