Posted by riverbend on November 23, 2009 at 16:17:11 from (208.160.33.254):
In Reply to: carb freeze posted by dirtdog 38 on November 23, 2009 at 14:47:10:
I'm not sure. It sounds like your tractor is swallowing it's tongue when you give it some throttle. That may or may not be related to the frost.
All carbs frost up when the tractor is first started on wet chilly days. I think the venturi is acting like the expansion valve in a refrigeration unit. Once my tractor (H) warms up, the frost melts away, but it generally runs fine.
When your carb is frosted up and the tractor dies, take the carb off and look inside it. Is the ice covering the idle fuel port ? If so, that's the problem and once the ice melts, you're good to go.
If it the same on a hot day, I'm guessing something else is wrong with your fuel system. Try posting again with a few more details on what happens. Will it ever take full throttle ?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
