Re: 1466 3 point jambed in the up position
Posted by The tractor vet on November 23, 2009 at 18:14:45 from (99.167.217.134):
In Reply to: 1466 3 point jambed in the up position posted by steve mahac on November 23, 2009 at 15:15:03:
Remove the top link plate and look inside with a light and you will see and arm or lever coming up from the bottom of the rearend and you will see a lever hanging down from the top , the one on top goes on the back of the one from the bottom these two levers are on the rightside near the rear case . Now it is wise to use a hook or atleast a pair of cloves when trying to get the top one to the back side of the one coming up from the bottom as the top one is heavy spring loaded .Now if the plows are still up whe you go to do tis either use a loader to remove the plows from the three point or Block them up , IF ya don't they will move then likely fall . It also helps to wire back the draft control lever as this will reduce the spring tenchion on the top lever .
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
