Re: trying to get my M running
Posted by Janicholson on November 23, 2009 at 19:40:47 from (64.61.211.134):
In Reply to: trying to get my M running posted by Jake in NY on November 23, 2009 at 19:14:00:
Those can have the starter jamb into the teeth of the Flywheel and lock. For first attempts, put it in high gear and rock the daylights out of the rear tires forward and back. If the fan moves, it is not jammed. I would see if the lights work, if not find out why!. If they are turned on, and the starter is engaged they should dim way down if the starter is jammed or the engine is stuck.
If the engine is stuck, take out the plugs and pour in about 1/4 cup of auto trans fluid in each hole. Reinstall the plugs and let it sit for several days. See the archives for details on both issues. Much good reading. JimN
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
