I'd still venture to say it's the carb, barring some memorable event such as overheating, removing the intake manifold, etc.
The best advice was checking for the vacuum leak.
I had the same situation of needing � choke to make it run right. After using brake cleaner around the manifold and carb, I noticed an increase in running condition when I sprayed around the throttle shaft.
Also, learn from me that, if you send it in to get rebuilt tell the re-builder you found the throttle shaft area to be problem. I originally sent mine in and when I got it back it ran the same. Sent it in the second time after talking to the re-builder and he replaced it for no cost. Didn't make it right, but wanted to fix it right.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
