Re: trying to get my M running
Posted by El Toro on November 24, 2009 at 04:09:40 from (74.103.74.58):
In Reply to: trying to get my M running posted by Jake in NY on November 23, 2009 at 19:14:00:
You need to make sure all battery connections are clean & tight including where the battery is grounded if the battery cables are cracked and frayed I would replace them with 00 battery cables. Take a screwdriver and short across the starter solenoid and see if the engine will crank. Make sure its out of gear and the brakes are set. To get the engine to start you need to do a few checks. If you have a distributor you need to check for battery voltage at the coil. With the points open you should have battery voltage on both small terminals. Clean the points with some 320 wet or dry until shiny. You need to make sure you're getting gas to the carburetor. The carburetor may be gummed up from sitting with old gas and the gas tank. Hal
