Re: trying to get my M running
Posted by mkirsch on November 24, 2009 at 05:04:33 from (64.80.108.57):
In Reply to: trying to get my M running posted by Jake in NY on November 23, 2009 at 19:14:00:
Make sure the engine isn't stuck by turning it over with the crank.
Make sure it actually has a key start, and not just a key ignition. Follow the battery wires. If you see a big button switch connected into the wires that looks like an old-fashioned high-beam-headlight floor switch, that's the starter button.
Assuming your Dad converted his M to solenoid start like my Dad did to his M: Do you get nothing, or a click? If nothing, the solenoid may be rusted up. If you get a click, you've got dirty contacts. Clean 'em up with battery terminal cleaner and one of those inside-outside battery brushes. If they're those clamp-on replacement battery ends, take them apart and clean them up too.
