Posted by mkirsch on November 24, 2009 at 06:29:21 from (64.80.108.57):
In Reply to: front end loader posted by MR B on November 23, 2009 at 12:13:46:
You're not going to find a site or serial number registry if you haven't found one yet through normal web searches. Loaders simply don't have the same passionate following as tractors. Luckily it's a loader so it should be pretty simple to figure out.
Since the loader presumably uses the tractor's hydraulic system, it will use the same fluid as the tractor. Farmalls use Hytran or hytran-compatible oil. Even if it doesn't, it's not that critical on antique equipment like this, so just use the hytran.
As for amount, you're on your own. Many Walmarts carry both major types of hydraulic oil (R&O type, and Hytran-compatible type), so you should have a supplier nearby if you run short. Fill it until it's full.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
