Re: distilate fuel plumbing
Posted by Mr. Mayor on November 24, 2009 at 08:51:50 from (12.155.240.215):
In Reply to: Re: distilate fuel plumbing posted by matthew scheirer on November 23, 2009 at 19:47:59:
Do you have all of the other stuff related to distillate like the radiator shutters, hot box manifold, manifold heat shield, dist. cylinder head, carb etc...??
