Re: Farmall M Runs When Choked - Need Help
Posted by rumplestiltskin on November 24, 2009 at 10:00:34 from (192.88.212.44):
In Reply to: Re: Farmall M Runs When Choked - Need Help posted by Mike Hawkey on November 23, 2009 at 21:43:56:
You're right, Mike.
The float can hang up not only on the bowl, but on the gasket as well if any of the gasket protrudes too far inside the bowl. I always use a sharp blade to trim the gasket to match the inside lip of the bowl -- being careful to clean out any shavings, of course.
There are so many possibilities here that this probably isn't the problem, but as long as he's checking all that other stuff...
Mark W. in MI
