Re: Farmall A - rebuiding eng.
Posted by El Toro on November 24, 2009 at 10:54:40 from (74.103.74.58):
In Reply to: Farmall A - rebuiding eng. posted by Tom R. S. on November 24, 2009 at 10:26:35:
I think I would install a new sleeve/piston kit& new sleeve seals. Have the crankshaft measured fo wear & have new valve guides installed if it needs them and have them magna-fluxed the head. You can get a sleeve kit off this forum for about $303.00. Hal
PS: Doing that it will last a long time and you increase the cylinder bore to 3.125" without any machining.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
