Re: hydraulic on m
Posted by mkirsch on November 24, 2009 at 12:11:14 from (64.80.108.57):
In Reply to: hydraulic on m posted by pheel on November 24, 2009 at 03:42:07:
pheel,
The charlynn pump will NOT work on the front of the tractor. It is designed to run at 540RPM. The engine runs at 1800RPM. It will ruin the pump.
You need a distributor-driven live hydraulic pump. It is not cheap, about $800 for the pump. You may need to change out the front engine cover on your M too, because they changed them in 1950 to fit the live pump. The live pump will not fit on an older M.
Rather than mess around with the belly pump as a reservoir, I recommend mounting a hydraulic oil tank around 3-5 gallons somewhere on the tractor.
