Re: carb freeze
Posted by riverbend on November 24, 2009 at 15:55:40 from (208.160.33.241):
In Reply to: Re: carb freeze posted by dirtdog38 on November 24, 2009 at 15:11:50:
I'm guessing that you have an other problem. The frost is incedental or a red herring. After idling for an hour, your tractor should be fully warmed up.
Is the carb actually the one for a 560 ? It sounds like the mixture is too lean when you pull the throttle open. What happens if you run it with a little choke and go to WOT ? How do your plugs look ?
Greg
