Re: Farmall 400 clutch finger height?
Posted by SDE on November 25, 2009 at 17:40:59 from (174.124.0.172):
In Reply to: Re: Farmall 400 clutch finger height? posted by Nebraska Kirk on November 25, 2009 at 17:11:07:
Disregard previous post.
Free length 3.156 from the top of the finger to the bottom surface, without any tension or preload on the springs.
The manual shows two dimensions that are used to set the height with the pressure plate bolted in place.
I bolted my pressure plate to a piece of flat metal. Use a spacer under the cover plate that measures 1.03. Now the height of the finger should be 2 and 5/16 from the top of the finger to the surface that the pressure plate is bolted to.
SDE
