Posted by Farmall Freak on November 25, 2009 at 17:52:15 from (68.118.200.10):
In Reply to: Spark Plug Wires posted by gary north of spokane on November 23, 2009 at 12:27:24:
To fix the stuck clutch in an open area put the tractor in gear with the clutch in and start it. Drive around and keep working the clutch. Once the clutch disengages enough to let the tractor stop it may not allow you to shift. If that happens shut it down and put it in fourth gear. Fire it up and put the front end against something solid and slip the clutch a few time then see if it will allow you to shift it may take some fooling aroungd but the clutch may eventually come around. Worst case scenario you have to split the tractor and put in a new clutch.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
