Posted by Owen Aaland on November 26, 2009 at 04:51:21 from (65.161.86.96):
In Reply to: 656 gasser oil pressure posted by theponyroper on November 25, 2009 at 05:46:55:
If the engine oil pressure is staying about the same under the varying conditions, it is an indication that the pressure relief valve is controlling the pressure at all times. That is a sign of a healthy oil system.
If a little drop in oil level in the hydro is making that much difference I suspect that you are not using the correct procedure to check the oil level. On the Hydro tractors, the oil level is to be check with the engine running. It needs to have been idling at least a couple of minutes before checking. On the Hydro tractors the Hydro transmission housing is kept completely filled while in operation. This will cause the oil level on the stick to drop a couple of inches after the engine is started. That is why you need to have the engine running to check the transmission/hydraulic oil.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
