Re: 1930 Farmall regular
Posted by Old-F20 on November 26, 2009 at 08:10:14 from (71.7.98.117):
In Reply to: 1930 Farmall regular posted by John N.B. Pa on November 25, 2009 at 16:03:05:
Andrew Z said: (quoted from post at 08:27:30 11/26/09) the anouther reason there are inspection holes on the sides, it is to remove the pistons from below without taking off the head. I tried putting them back in that way and i gave up and went from the top down like normal.
Andrew
thats the only way you get the pistons out. the end of the rod is larger than the sleeve is round. this is the case on all pre 39 engines
