Re: Frozen WD-9
Posted by rustred on November 26, 2009 at 08:27:44 from (72.172.100.113):
In Reply to: Frozen WD-9 posted by d282 on November 26, 2009 at 07:39:49:
your pretty darn lucky if thats all the damage you can see.could have been the block split wide open. probably do the simplist first, fix what you see and hope for the best. if you do get it running check for water in oil and external leaks around block and rad.or water blowing out exhaust. even if you had a small amount of anti freese in there damage is not so extensive as straight water.
