Re: sticking brake on an M
Posted by 504-2 on November 26, 2009 at 22:45:24 from (216.145.144.254):
In Reply to: sticking brake on an M posted by Rusty Acres, ND on November 26, 2009 at 20:58:20:
Just a guess, you have the brakes adjusted up so they work great but a little to tight and they are rusting to the hubs.(Just not enough clearance) Or the balls and plates are worn out allowing the balls to get past the ramps.
