Re: leaking gas tank
Posted by farmboycf on November 27, 2009 at 05:38:20 from (68.103.196.196):
In Reply to: leaking gas tank posted by plow hand on November 26, 2009 at 23:58:49:
That is a easy fix. Take tank off and take to the carwash and use warm soapy water and just clean it up then take some methonal and put in there and shake it and get all the water out and let it dry over night. you can buy this stuff call Red Coat you put it in there and roll your tank around and put a good coat all over this tank andyour problem are solved for every no more rust.
